Author Topic: Deleting a package  (Read 8265 times)
Model Trainer
Deleting a package
« on: June 20, 2024, 02:08:10 am »
I imported several process maps from a BPMN modeling tool into Sparx repository, where I'm working mainly within ArchiMate notation. Now, it seems that my model is so huge to be processes timely, so I decided to delete those processes from my model, but it took almost 1 hour and Sparx couldn't do that. It seems that Sparx has crushed. What's the issue? and does any body know any solution to that?
Bets Regards
Re: Deleting a package
« Reply #1 on: June 20, 2024, 04:01:17 am »
The solution depends on what the actual problem is.
In normal circumstances, you should be able to add any number of models without a noticable impact on the performance.
That however depends on two things:
the database you are using
  Good: MySQL, SQL Server, SQLite (.qea file),..
  Bad: Jet(.eap), Oracle
the connection to that database
  Good: local file, machine in the same network
  Bad: WAN connection over a VPN from client to database
« Last Edit: June 20, 2024, 02:43:51 pm by Geert Bellekens »
wivel
  • Driven by Models
« Reply #2 on: June 20, 2024, 07:48:12 am »
Have you tried deleting them in smaller chunks?
Henrik
Model Trainer
« Reply #3 on: June 21, 2024, 04:12:41 am »
We don't have any special DBMS for Sparx now. We're saving them on a file-based repository within our shared or local places.
I tried to delete them in chunks, but even with this approach, Sparx is crushed and tried to work almost 50 minutes without any result.
« Reply #4 on: June 21, 2024, 02:41:52 pm »
For local files it also matters which one.
Move to .qea if possible, or even better, move to real database.
And maybe try a Project integrity check before deleting.
DeBAAT
« Reply #5 on: June 21, 2024, 03:31:09 pm »
It looks like this may be too late or might not be appropriate at all, yet I would like to make the remark. Sorry for that.
In situations like this, I try to add these kind of large chunks to a copy of the repository to do some testing first.
It is especially easy when working with file based repositories.
That way the original file is still available for normal operations.
