Author Topic: Sticky URL HTML report diagram  (Read 5138 times)
Kristof De Kimpe
« on: June 24, 2024, 05:53:01 pm »
We are on Enterprise Architect 16.1.1628 Build 1628.
We publish on a daily basis to HTML (using Publish > Standard HTML report).
We used to reference diagrams via diagram's ID in an URL. Since our latest upgrade we notice the URL redirection works differently using redirection in the browser.
For example: https://ea.example.com/?guid=60DA9B62-0C87-45b1-BF06-5ADDF3E3DD0A was sticky and now redirects to https://ea.example.com/EARoot/EA2/EA2/EA38.html only valid for the given export.
Has this changed since in between versions? Or has this been a customization at our end that we have lost since the upgrade?
Thanks in advance!
Re: Sticky URL HTML report diagram
« Reply #1 on: June 24, 2024, 06:35:26 pm »
Kristof,
Can you explain how this is different from the previous version?
I would expect https://ea.example.com/?guid=60DA9B62-0C87-45b1-BF06-5ADDF3E3DD0A to always end up at the correct page, regardless of how many times you regenerate the export.
Is that not the case?
That actual html page might be different every time you regenerate, but that has always been like that.
Kristof De Kimpe
« Reply #2 on: July 05, 2024, 01:48:26 am »
Thanks for the confirmation this hasn't changed in Enterprise Architect lately!
Probably the web service configuration (URL redirection rules) were changed, causing the changed behavior.
