Author Topic: Reuse model element under version control  (Read 11567 times)
Mercurius
« on: July 08, 2024, 09:12:36 pm »
I have difficulties to reuse a model element which is an a separated version controlled package. Maybe someone can help?
There are two packages:
- A package "Main Package" which includes a block "Context" and a diagram for its architecture
- A package "Module Package" which includes a block "Module" that shall become part of "Context"
Both packages are version controlled.
Now I do the following:
- Check out "Main Package"
- Put "Module" from "Module Package" (which is not checked out or locked by anybody) as a link on the diagram in "Main Package"
- Draw a "Part Association" from "Module" to "Context"
All that works well. And it should since I do not do any changes for "Module".
But now either one of the following happens:
a) After saving, closing and reopening the diagram, "Module" has been silently removed from my diagram OR
b) After a short moment message "The diagram has been modified by another user. It will remain locked against modification unitl it is reloaded." appears.  Whatever I click now, "Module" is removed.
How can I reuse "Module"? Since I am not working on "Module", I am also not allowed to check it out.
Re: Reuse model element under version control
« Reply #1 on: July 08, 2024, 09:30:23 pm »
This means you are actually changing Module, and that should not be allowed if you didn't check-out the package containing Module.
But there is no reason the element should be removed from your diagram.
I would try a project integrity check.
Mercurius
« Reply #2 on: July 08, 2024, 10:03:28 pm »
Hi Geert
Thank you for your quick answer.
I tried it with a different module without the Part Association. Just showing it on the diagram. Even then it is the same behavior. :-(
Integrity check did also not find anything suspicious.
Maybe it is a bug of the version control addin?
« Reply #3 on: July 08, 2024, 10:07:55 pm »
Which version control add-in are you using?
I was assuming you are using the build-in version control integration.
Mercurius
« Reply #4 on: July 12, 2024, 09:30:41 pm »
It is called "LimeJuice".
« Reply #5 on: July 12, 2024, 10:22:40 pm »
What is that? A derivative of LemonTree??
Mercurius
« Reply #6 on: July 16, 2024, 07:16:12 pm »
It seems to be some kind of legacy add-in, which is still used by my client.
Do you think that this add-in would be the origin of the mentioned problems?
(If the EA Guru confirms, I might have better chances to convince my client to change that.)  ;)
Thanks and regards
« Reply #7 on: July 16, 2024, 08:15:47 pm »
Without knowing the add-in there is no way we can confirm or deny if this add-in is the source of your problem.
All I can say is that version control isn't supposed to work like that.
Takeshi K
    • Sparx Systems Japan
« Reply #8 on: July 17, 2024, 09:53:39 am »
Hello Mercurius,
I have heard of a similar problem (EA's behaviour is the same) and if I remember correctly the problem has now been fixed.
If you are not using the latest build of version 16.1, it is worth trying the latest build.
t-kouno
Mercurius
« Reply #9 on: September 17, 2024, 06:41:27 am »
Hello Takeshi K
The problem got even worse, but indeed after updating from build 1623 to 1628 it seems to be solved. Thank you very much for your idea.   :D
Mercurius
