Author Topic: Missing bookmarks in generated document  (Read 17198 times)
pb17
« on: July 31, 2024, 07:40:43 pm »
Hi everyone,
I am having trouble with non-working hyperlinks in a document generated from Enterprise Architect. The hyperlinks, as usual, have expected structure with the prefix (#BKM_) and Ea_guid, but they do not link to any element in the document. Each hyperlink is composed correctly, but instead of linking to a specific place or reference in the document, they are not linking to anything.
To generate this output, I´m using the following template and fragement. This templa searchs the endpoints for a given connector and used the information of the source to poulate the Fragament "Template A"
This problem seems to be related to the specific structure of the template. I am using a similar approach to populate other chapters of the document, and the hyperlinks are created correctly. However, in this other structure, I do not use filters to retrieve the elements.
 Instead, I feed the fragment directly with the target information. I have tried changing the header style, adding bookmarks in the element names, but none of these solutions have worked.
Has anyone else encountered this issue?
images can be found here : https://stackoverflow.com/questions/78815516/missing-bookmarks-in-generated-document
