Author Topic: Filtering elements on diagram?  (Read 11692 times)
ea0522
« on: August 01, 2024, 04:07:17 pm »
In our repository, we have diagrams showing process descriptions using ArchiMate Business Layer elements.
The same diagram also shows how the Business Layer elements are related to Application Layer elements.
I.e. a Business Process is serviced by an Application Service which is realised by an Application Component.
For most of our users, the Business Layer will be sufficient.
Some of our users are interested in both layers.
Would it be possible to have a user (not the creator) of the diagram to filter on the type of elements to be shown in the diagram?
I.e. do not show all elements belonging to the Application Layer. (Or only show elements belonging to the Business Layer).
The brute force option is to duplicate the complete diagram and remove the Application Layer elements.
This however does not have my preference as it will be hard to maintain the diagrams.
Re: Filtering elements on diagram?
« Reply #1 on: August 01, 2024, 04:26:11 pm »
Have you tried the diagram filters?
I guess it should be possible to create a filter to do just that.
ea0522
« Reply #2 on: August 01, 2024, 05:12:08 pm »
Thanks for the quick reply.
And yes, I tried the diagram filters however, they only seem to work for me, not for anyone else.
I was hoping for a solution which would be more user-friendly like a button on the diagram or something.
« Reply #3 on: August 01, 2024, 05:38:46 pm »
You should be able to define diagram filters that can be used by anyone.
If you want a "button on the diagram", you'll have to script something.
DeBAAT
« Reply #4 on: August 02, 2024, 04:28:49 pm »
This sounds very interesting.
Can't find anything in the documentation on how to get a "button on the diagram".
Any hints as to where to look?
« Reply #5 on: August 02, 2024, 04:32:04 pm »
You can't get a literal button on a diagram, but you can create a script that you can execute from the context menu on a diagram, or as a reaction to opening the diagram.
shimon
« Reply #6 on: August 05, 2024, 03:20:20 pm »
Did you consider using the Diagram Legend to accentuate the more relevant elements?
The others are still visible, but the "interesting ones" may have a different background color or different boundary color and width.
Right clicking on the Legend gives anyone the choice of "Toggle Auto Color".
You can define more than one legend one any single diagram, and they can be-reused by dragging them onto many diagrams.
It's not a perfect solution, but may suffice.
If you are into experimenting, you may choose a default font the is the same color as the goto color of the legend, and then these elements will be almost invisible when using this filter.
Sincerely,
Shimon
ea0522
« Reply #7 on: August 06, 2024, 03:44:12 pm »
Thanks for the suggestion Shimon.
I did try the legend option and it has some flaws.
First is that I cannot change the color of the font on the elements, so they are still visible. And I don't know how to change that with a filter of some sort.
Furthermore, there is the issue of publishing the diagrams in Prolaborate.
It looks like Prolaborate is not supporting dynamical diagrams. At least I have not found an option to toggle the "Auto color" option of the legend element to show a different diagram in Prolaborate.
Still looking for an elegant solution, the best I can think of now is to have two diagrams. Despite the additional burden of maintainance...
