Author Topic: Model Default Diagram does not start  (Read 46209 times)
Viking
« on: August 23, 2024, 06:53:48 pm »
Hi, this feature always worked in other setups, but for any reason I cannot set “Model Default Diagram” for everybody in the project in my current setup.
I followed the instructions in: https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_fundamentals/usr_model-default_diags.html.
My current setup is:
-   EA v16.1
-   MariaDB.
-   User Security is enabled in: Settings > Security > Administer > Enable Security.
-   Start > Collaborate > Model Home > Manage > Choose Default > …. I also tried Model Home > Set current as default.
-   I checked it with: Start > Collaborate > Open Model Diagram (which opens the correct diagram for me, but not for other users).
Suggestions are very welcome, V.
« Last Edit: August 23, 2024, 06:56:04 pm by Viking »
Re: Model Default Diagram does not start
« Reply #1 on: August 24, 2024, 06:03:29 am »
Query usys_system.Default_Diagram. It should contain the guid of your diagram
« Reply #2 on: August 26, 2024, 03:19:32 pm »
I suspect this issue is that the model default is overridden by any user who has specified their own default.
Make the current diagram the default diagram displayed when any user re-opens this model.
Where "any user" actually means any user that doesn't have a user default diagram set.
Viking
« Reply #3 on: August 26, 2024, 04:53:11 pm »
Many thanks, @Qwerty. I checked this and the entry (GUID) is correct. But the diagram (with this GUID) does not open in the EAs of the other team members :(
Viking
« Reply #4 on: August 26, 2024, 05:40:08 pm »
Many thanks @Eve. The users just installed EA and have no idea about this feature. No, they did not configure their own default diagram
« Last Edit: August 27, 2024, 12:57:53 am by Viking »
Viking
« Reply #5 on: September 09, 2024, 09:14:03 pm »
[SOLVED] In the shortcut was a wrong (none existing) GUID. I assume the shortcut overrules the other entries.
philchudley
« Reply #6 on: March 05, 2025, 02:32:14 am »
I know its an old thread, but the following is relevant to something I am working on:
Which table is that? I can only find tables that begin with t_
I am looking for where the default diagram is set within the repository tables.
Phil
Models are great!
« Reply #7 on: March 05, 2025, 04:59:29 pm »
Phil
Hi Phil,
It's in t_xref, Name=DefaultDiagram, Type=element property
IIRC, there's also a linkage in PDATAn  (if you're thinking of manipulating things directly).
philchudley
« Reply #8 on: March 05, 2025, 08:41:04 pm »
Thanks! Will check that out
Phil
Models are great!
