Author Topic: Connector Properties  (Read 16882 times)
tweber
« on: September 06, 2024, 10:12:47 pm »
in the EA.Connector type, there's an attribute, Properties.  I'm assuming it's a collection, but have not been able to map it to a specific EA element  (there's no EA.Property that I can see).  TIA for any help.
Re: Connector Properties
« Reply #1 on: September 06, 2024, 10:26:21 pm »
tweber
« Reply #2 on: September 06, 2024, 10:58:57 pm »
THanks, Geert.  I found that information.  My issue is that while the EA.Connector has a Properties attribute, which I assume is an EA.Collection, I haven't been able to find an EA.xxxxx that each item in the collection maps to.  There's no EA.Property.
« Reply #3 on: September 06, 2024, 11:14:11 pm »
I posted the second link as well didn't I https://sparxsystems.com/enterprise_architect_user_guide/16.1/add-ins___scripting/properties2.html
There is no EA.Collection, and you shouldn't assumer there is. You can use this object using the Item() method. That method return a Property object/structure that has it's attributes documented on this same page as well.
tweber
« Reply #4 on: September 07, 2024, 12:11:55 am »
in jscript (and I assume in vbscript as well), I can create a declaration "var coll as EA.Collection;", which is an array with methods, one of which is "coll.GetAt()", which will return an element of that collection (I'm sure you know all of this).  My issue is that while the connector (i.e., EA.Connector) has an element called "Properties", which appears to be a collection, as I can retrieve properties.Count. However, I've not found what element it is a collection of.  In your second link, there's a Property class.  In jscript, I can't create a 'Property' using "var prop as EA.Property".  EA.Property doesn't appear to exist.
« Reply #5 on: September 07, 2024, 06:47:02 am »
I'm not sure in how many ways I can repeat the same thing. EA.Connector.Propertis is NOT an EA.Collection. It is an EA.Properties class documented here: https://sparxsystems.com/enterprise_architect_user_guide/16.1/add-ins___scripting/properties2.html
It's not because it has a property called Count that it's a EA.Collection.
tweber
« Reply #6 on: September 09, 2024, 10:05:45 pm »
It's possible that in VBScript, EA.Properties exists.  In JScript, it doesn't.  I can see conn.Properties within JScript, but cannot access it.  In fact, it appears to have the same attributes as an EA.Element when I use JScript's autofill.  I will also reiterate that in JScript, there's no EA.Property that I can map one of the conn.Properties to.  And yes, I've seen both Properties and Property in the manual.  I just can't extract anything from them.
« Reply #7 on: September 10, 2024, 12:06:06 am »
There's only one API for both Jscript and VBScript (and C# and Python, and...)
Can you post the code you are using and indicate where it goes wrong?
tweber
« Reply #8 on: September 10, 2024, 12:46:48 am »
Here it is:
function dumpConnectorInfo() {
                var elem        as EA.Element;
                var conn        as EA.Connector;
                var selectedObjects                                     as EA.Collection;
                var diagObj        as EA.DiagramObject;
                var conns        as EA.Collection;
                var diag        as EA.Diagram;
                var props        as EA.Properties;           // <--- no such EA element exists
                var prop        as EA.Property;                               // <-- no such EA element exists
                Repository.EnsureOutputVisible("Script");//opens the output window
                Repository.ClearOutput("Script"); // clears the output window
                diag        = Repository.GetCurrentDiagram();
                selectedObjects = diag.SelectedObjects();
                if(selectedObjects.Count > 0) {
                                for(var i = 0; i < selectedObjects.Count; i++) {
                                                diagObj        = selectedObjects.GetAt(i);
                                                elem        = Repository.getElementByID(diagObj.ElementID);
                                                conns        = elem.Connectors;
                                                if(conns.Count > 0) {
        for(var j = 0; j < conns.Count; j++) {
        conn                                                     = conns.GetAt(j);
        Session.Output("conn name " + conn.Name );
        Session.Output("   objType " + conn.ObjectType );
        Session.Output("   stereo " + conn.Stereotype );
        Session.Output("   metaType " + conn.MetaType );
        conn.Properties;
        if(conn.Properties.Count > 0) {                                                // this does exist
        for(var k = 0; k < conn.Properties.Count; k++) {
        Session.Output(" prop name " + conn.Properties.Name);  // << this breaks also
                Session.Output("Done.");
« Reply #9 on: September 10, 2024, 01:33:47 am »
This works:
function main()
conn = Repository.GetConnectorByGuid("{3410D31C-97AA-4b70-AB0A-469C637B67C0}")
conn.Properties;
Session.Output(" prop name " + conn.Properties.Item(k).Name);
Session.Output(" prop Value " + conn.Properties.Item(k).Value);
Session.Output(" prop Type " + conn.Properties.Item(k).Type );
Session.Output(" prop Validation " + conn.Properties.Item(k).Validation );
main();
tweber
« Reply #10 on: September 10, 2024, 10:05:57 pm »
Thanks, Geert.  I was able to access Properties that way. And, you were correct in indicating that the info is quite carefully hidden in plain sight in the manual.:)
