Author Topic: EA_OnPostNewConnector, find the Attribute end, if the Connection is to Attribute  (Read 12510 times)
Ribeye
My C# plugin is using EA_OnPostNewConnector to trap when the user creates a new connection, obviously.
One of the nice features of EA is that it allows the user to create a connection from an Attribute of a Class, not just a Class. You select the Attribute and drag from the { that pops up to the target Class.
From within EA_OnPostNewConnector I get the Connection that has been created by the user from the EA.EventProperties eventProperties parameter of EA_OnPostNewConnector.
     repository.GetConnectorByID(eventProperty.value) does the trick.
To test if the Connection is from an Attribute, I am expecting newConnector.StyleEx to have the Attribute details.
But I am seeing ""
I am seeing only one EventProperty in EventProperties, so the Attribute details are not there.
Question: within EA_OnPostNewConnector, how do I find the Attribute end, if the Connection has an Attribute end, not a Class end?
I don't think you can. I suspect that information isn't determined until after the broadcast.
