Author Topic: BABOK User Stories  (Read 7711 times)
Nrido
BABOK User Stories
« on: September 17, 2024, 11:41:19 pm »
I would like to add user stories in EA. I stumbled upon some kind of an add-on (or perspective / methodology?) called BABOK.
In BABOK perspective I found User story diagram, with custom toolbox that contains everything I need (persona, epic, theme, user story). I found it much better than just a simple user story element hidden inside Use Case diagram artifacts.
I then generated a sample pattern, but what I dont understand is that elements from that pattern look visually quite different than the actual elements from the Toolbox (basically it looks like UML REQ).
See printscreen:
I know how to show or hide requirements section of an element, but it still looks wildly different. I already tried various settings almost everywhere. I also found some kind of a user guide for BABOK, but there was zero mention of user stories.
Re: BABOK User Stories
« Reply #1 on: September 17, 2024, 11:47:23 pm »
Are they using the infoview?
Nrido
« Reply #2 on: September 18, 2024, 12:00:43 am »
No, in both cases info view is not enabled. I also checked stereotype in properties and in both cases it says "BABOK::user story".
Is it possible that those elements are different versions? So the sample pattern is an old version and the actual element in the toolbox somehow changed later on?
« Reply #3 on: September 18, 2024, 03:12:42 am »
ah, might set to show rectangular.
Nrido
« Reply #4 on: September 18, 2024, 06:47:30 pm »
Thank you, that should be it! Its precisely shown in this article as well (last picture): https://blog.sparxsystems.de/en_GB/ea/grundlegende-konzepte-element-notizen-im-diagramm-anzeigen/
I just dont have that icon (I have element icons enabled and I see other icons on the right of the element) nor do I have the option for showing rectangular view in appearance (I have currently version 15.2).
« Reply #5 on: September 18, 2024, 07:26:13 pm »
Should be here: https://imgur.com/MDs1QAv
« Last Edit: September 18, 2024, 07:29:12 pm by Geert Bellekens »
Nrido
« Reply #6 on: September 18, 2024, 09:07:17 pm »
Oh yes this is it, thank you very much. I was blind.
