Author Topic: [EA17] EA does not evaluate COM objects in JavaScript debugger anymore  (Read 26952 times)
Roman Liebsch
In 17 I am not able to debug java scripts and evaluate for instance COM objects like a Msxml2 DOMDocument in the "Locals". They are not shown at all. And if I try a mouse-over on such variables the debugger even stops execution.
In EA 16 it is working perfectly fine.
I might remember in former EA version where you have to install the old Microsoft Script Debugger but I guess Sparxs completely swtiched to JavaScript.
Anyone the same issue or even a solution?
Thanks!
Roman
Roman Liebsch
Re: [EA17] EA does not evaluate COM objects in JavaScript debugger anymore
« Reply #1 on: October 24, 2024, 07:03:53 am »
I found a workaround.
If I use the VEA folder from EA 16.1.1628 in the EA17.0.1703 folder then symbols arise again.
BUG is reported to EA now.
ngong
« Reply #2 on: October 29, 2024, 06:17:47 am »
Running my JScript in EA17, that worked fine in EA16, led to
[42272393]      Agent: Started
[42272423]      Failed to get EA::IDualApp interface [0x80029c4a]
[42272425]      Microsoft Process Debug Manager creation Failed: 0x80040154
[42272425]      This is included as part of various Microsoft products.
[42272425]      Download the Microsoft Script Debugger to install it.
[42272425]      Failed to initialize JScript engine
[42272426]      Debug Session Ended
Could this be the same issue or should I look for a no-longer-supported version of the Microsoft Script Debugger?
Rolf
