Author Topic: Extend SysML with MDG Technology in EA  (Read 21078 times)
Plonka
« on: September 26, 2024, 01:28:44 am »
Hello all,
I simply want to extend the SysML 1.5 TestCase.
Lets say I want to have in the Properties a new Attribut that let me choose if the TestCase is executed or not.
My approach is the following:
1. Create a new projekt: Start Page->Create from Pattern-> MDG Technology Builder
2. In the <<profile>> Package I added the SysML 1.5::testCase
3. I added a stereotype (extendedTestCase) and added the attribut "Status"
4. I created an enumeration (EnumStatus) and added the attributs "executed" and "not executed".
5. The type of the attribut "Status" selected as EnumStatus
6. I connected the "extendedTestCase" and the "SysML 1.5::testCase" with an Extension connector
Later I exported the <<profile>> Package to an xml file which I later choose when generating the MDG-Technologie.
I kind of have the feeling that I can not simply extend a SysML Stereotype. I can integrate my Technology into my project but I can not find the "extendetTestCase".
Are there any good instructions on how to extend sysml elements in EA?
A Youtube video or a webpage oder something I can find in this Forum. I was not able to find anything reasonable.
Hope somebody can help.
Kind regards
J. Plonka
Re: Extend SysML with MDG Technology in EA
« Reply #1 on: September 26, 2024, 03:12:58 am »
That should be a Generalization instead of Extension.
Roche Pso
« Reply #2 on: September 27, 2024, 12:34:57 am »
Do you still need to also extend the UML base type, or does specialising a SYSML type work by itself in the latest versions?
« Reply #3 on: September 27, 2024, 02:08:26 am »
I still do it because of the profile helper for toolboxes.
Plonka
« Reply #4 on: October 22, 2024, 08:42:39 pm »
When I extend the «metaclass» class and generalize a «block» in my Profile, the new Element in my new Element is from type Class and not Block.
How can I change this?
My new Block should behave and look exactly like a SysML Block but I want to extend with some attributes.
Any ideas?
« Reply #5 on: October 22, 2024, 09:42:46 pm »
Any ideas?
did you fill in the metatype field?
Plonka
« Reply #6 on: October 22, 2024, 10:28:40 pm »
«metaclass»
Type: Class
Stereotype: UML Standard Profile::Metaclass
«Block»
Type: Block
Stereotype: SysML 1.5::block
My new Block is a Stereotype element of the Toolbox "Profile"
Type: Class
Stereotype: Stereotype
New Block --- Generalization ---> «Block»
New Block --- Extension ---> «metaclass»
I dont know where to "fill" the metatype field because there is no field in my New Block.
(I wish this forum would allow to add screenshots  ;D)
« Reply #7 on: October 22, 2024, 10:56:53 pm »
Please use the Profile helper to fill in the details. (right click and choose "Edit with profile helper")
Metatype is one of the fields you can fill in for a steretoype.
You can post images here if you first publish them on some kind of public image hosting site such as imgur.com and then put the link between img tags.
Plonka
« Reply #8 on: October 22, 2024, 11:29:36 pm »
That looks better, thank you.
Next step would be to change the appearance with Shape Script.
I want the new Block to look like a SysML Block but slightly different when some attributes have a specific value.
I managed to this in general but there is no source code for the SysML Block shape script or the UML Class element.
« Reply #9 on: October 23, 2024, 01:23:25 am »
Shapescripts that deal with attributes are very difficult to get good.
There's only so much you can do with the tools provided by shapescript.
I usually tell people I can't do anything more then adding a bit of decoration for the class shape.
