Author Topic: Access to Security (User/Groups) via Java API  (Read 5536 times)
Toni Menzel
« on: August 09, 2013, 11:43:00 pm »
Hi again,
i did not find an API to access (read/write) the User/Group information in the eaapi.jar. Is it not accessible or am i just blind? Any chance to see it in future versions?
Am i correct that the only way to access it is using direct SQL queries (from within the API) ??
Toni
Re: Access to Security (User/Groups) via Java API
« Reply #1 on: August 10, 2013, 12:03:59 am »
I have never used the EAAPI.jar but would not know why it should be different from the standard API. Though I read quite a number of posts where people have difficulties using Java to code against EA which others (e.g. C# hackers) do not have.
Toni Menzel
« Reply #2 on: August 10, 2013, 12:08:53 am »
Thanks "qwerty".
Then maybe coming from there, what would a C# hacker do? Is there an API for security control ? (other than Repository.getIsSecurityEnabled:boolean)
« Reply #3 on: August 10, 2013, 12:27:27 am »
Well, there's not so much available indeed. Geert has posted some hacks here how to circumvent that. And his add-in framework has some additional framework too. You should check that out. (Try a search for Geerts posts regarding "security"; use the search button top right; extend time to one year). Many of his hints are based on the security description found in my Inside book.
« Last Edit: August 10, 2013, 12:29:20 am by qwerty »
« Reply #4 on: August 26, 2013, 04:48:55 pm »
Hi Tony,
Most of the security objects and functions haven't been exposed in the API (Java or C#), so the only workaround is to get the information using SQL, and if needed even update the database directly.
For queries you can use Repository.SQLQuery, for updates you'll need Repository.Execute
« Reply #5 on: August 26, 2013, 09:50:06 pm »
I've described the security tables in my Inside book.
