Author Topic: Alternate scenario entry point - possible to switch to other basic step?  (Read 13008 times)
Elpis
  • Make MDA/MBSE vital.
Is it possible to change step of Basic Path scenario, where Alternate scenario "forks" (aka entry point)?
I mean simple switching e.g. from 5a into 6a, without deleting whole alternate scenario (5a) and creating new one at basic step 6.
Re: Alternate scenario entry point - possible to switch to other basic step?
« Reply #1 on: October 05, 2024, 01:19:41 am »
Yes, open the main scenario, and right click. on the current entry point to remove it (you are not removing the scenario, only the entry point)
Then select the new entry point, and click the alternate/exception button to select your existing scenario.
Elpis
« Reply #2 on: October 11, 2024, 09:59:03 pm »
Thanks Geert. The dialog window with question "Are you you want to delete the currently selected item?" (context menu is invoked on a list element referring alternate scenario...) and subsequent disappearing of alternate scenario from the list, misleaded me. The scenario remains in owning UC, indeed. Need to treat "Entry points" list's title literally ("entry point" vs "entered scenario (aka Path)").
« Last Edit: October 11, 2024, 10:02:29 pm by Elpis »
