Author Topic: Joining t_connector with t_object, etc.  (Read 19761 times)
BCGoitcwoodard
« on: October 30, 2024, 06:30:12 am »
I am writing a repository query to obtain "data element lineage".  I have one model in XML and another imported from Oracle.  I have mapped the source/target relationships in Sparx using connector_type = 'Information Flow' as the base class and a custom stereotype = 'ETLMapping'.
We have mapped the source XSDelement(s) to the destination database columns.
(An oversimplification) It seems like when I select the connector_id, the XSDelement name (as an attribute of the XSDelement), and the database column as an attribute of the table), I am getting too many rows returned.
I have seen that an attribute object_id is equal to the object_id of the parent, and that the start_object_id and End_Object_id of the connectors are equal to the source and destination object_id(s).
Am I missing something?
Thanks in advance.
CCW
Continuing...
Here's the query as I described.
[size=8pt]
With cte_workday_etl_package_diagram as
(select
p.Package_ID
,p.Name Package_Name
,d.Diagram_ID
,d.Name Diagram_Name
from t_diagram    d
inner join t_package p on (d.Package_ID = p.Package_ID )
where p.Name = 'Workday ETL Mapping'
) --returns 4 rows
, cte_workday_etl_diagramobject as
(select distinct
do.Object_ID
,etldo.Object_Type
,etldo.Stereotype
from t_diagramobjects do
inner join t_object etldo on (etldo.Object_ID = do.Object_ID)
where do.Diagram_ID in
(select pd.Diagram_ID
from cte_workday_etl_package_diagram pd
and
(etldo.Object_Type = 'Class'
and etldo.Stereotype in ('XSDComplexType', 'Table')
) --13 rows, source and destination containers intermingled.
, cte_workday_ETLMapping_connector as
( select distinct
conn.Connector_ID
, conn.Start_Object_ID
, conn.End_Object_ID
from t_connector   conn
where
conn.Start_Object_ID in
(select Object_ID
from cte_workday_etl_diagramobject)
and
conn.End_Object_ID  in
(select Object_ID
and conn.Connector_Type = 'InformationFlow'
                and conn.Stereotype = 'ETLMapping'
) --70 rows- sounds okay
select * from cte_workday_ETLMapping_connector etlconn2
inner join t_object so on (so.Object_ID = etlconn2.Start_Object_ID)
inner join t_object eo on (eo.Object_ID = etlconn2.End_Object_ID)
-- -- -- -- -- -- -- -- TESTED OK ABOVE HERE -- -- -- -- -- -- -- -- -- --
        -- -- -- -- -- -- -- -- -- 70 rows returned. -- -- -- -- -- -- -- -- -- -- -- --
--inner join t_attribute sattr on (sattr.Object_ID = so.Object_ID )
--inner join t_attribute eattr on (eattr.Object_ID = eo.Object_ID )
When the last two commented lines are added back into the query, the result set goes from 70 rows to 127598 rows.
« Last Edit: October 30, 2024, 07:06:59 am by BCGoitcwoodard »
Re: Joining t_connector with t_object, etc.
« Reply #1 on: October 30, 2024, 09:54:22 am »
I'm not that proficient in SQL (like Geert who will probably know), but joining attributes to your result does not make me wonder why the number of rows explodes. I guess you have quite some attributes , don't you?
« Reply #2 on: October 30, 2024, 07:44:37 pm »
70 results are the connectors.
But each connector can be linked to the same object, so you have duplicates in your object id's; and thus duplicates in your attributes.
Lets say you have one object that has 10 attributes and 5 connectors. In your query that would result in 50 attributes.
BCGoitcwoodard
« Reply #3 on: October 31, 2024, 12:23:58 am »
Thank you, Geert.  But I think there might be another problem.
I am relying on t_attribute.Object_ID to identify the child XSDelement/Column where
the child (sattr.Object_ID = the parent so.Object_ID) and that would indeed give duplicates.
What about using t_attribute.ea_guid to "uniqueify" the children within a parent? ...or possibly t_attribute.ID?
I am not seeing how to code the join between the connector and the "child" XSDelement/Column so as to get distinct combination of source attribute / connector / destination attribute.
CCW
BCGoitcwoodard
« Reply #4 on: November 01, 2024, 08:00:42 am »
Geert,
This is the real question, I think.  How to retrieve from the Sparx repository using SQL the features at the two ends of a connector.
It is obvious visually in a diagram, and the containing objects have their Object_ID foreign keys in the connector, but how is the feature level connection stored in the repository database?
1.  I just had a thought.  What does Sparx do when you right-click on an "association" in a diagram and select "Link to Element Feature"?
2. I do not see any consistent way that the SourceRole and DestRole columns in the t_connector table are used.   ???
Any explanation from anyone is appreciated!
CCW
« Reply #5 on: November 02, 2024, 03:11:52 am »
Ah, you are trying to query Link to element feature
The details of the linked features are stored in the StyleEx column (or something similar)
I'm sure there are a number of topics on this forum that contain SQL queries for this.
BCGoitcwoodard
« Reply #6 on: November 02, 2024, 05:21:45 am »
…Not seeing it yet. still searching in documentation...Do you know of a more specific answer to my question?
Thank you,
CCW
« Reply #7 on: November 02, 2024, 06:06:45 am »
use the search function with keyword LFEP
Also https://stackoverflow.com/questions/40083327/sql-link-to-element-feature
BCGoitcwoodard
« Reply #8 on: November 14, 2024, 03:09:33 am »
Thanks much, Geert!  Here is the solution query for my situation, retrieving attribute level detail for the two ends of a connector.
[color=blue][size=10pt]
[font=courier]
USE [SparxProjects]
GO
/****** Object:  View [dbo].[vSparx_Workday_ETL_Source_Target_Object_Element_Mapping]    Script Date: 11/13/2024 10:09:21 AM ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
create  or alter  view [dbo].[vSparx_Workday_ETL_Source_Target_Object_Element_Mapping]
as
(select distinct
p.Package_ID
,d.Diagram_ID
from t_diagram    d
, cte_workday_etl_package_diagram_object as
(select distinct
pd.Package_ID
,do.Diagram_ID
,do.Object_ID
,o.Name Object_Name
,o.Object_Type
,o.Stereotype Object_Stereotype
,pd.Package_Name
,pd.Diagram_Name
inner join  cte_workday_etl_package_diagram pd
on (pd.Diagram_ID = do.Diagram_ID)
inner join t_object o
on (o.Object_ID = do.Object_ID)
where
(o.Object_Type = 'Class'
and o.Stereotype in ('XSDComplexType', 'Table')
, cte_workday_etl_diagram_object_element as
(select distinct
pdo.Object_ID ETL_Object_ID
,pdo.Object_Name ETL_Object_Name
,attr.Name ETL_Element_Name
,attr.ea_guid ETL_Element_guid --will be used to join connector end info
from cte_workday_etl_package_diagram_object pdo
inner join t_attribute attr on (attr.Object_ID = pdo.Object_ID)
, cte_conn_end_guids as
(select conn.connector_id
,conn.StyleEx
,SUBSTRING(conn.StyleEx
,CHARINDEX('{' ,SUBSTRING(conn.StyleEx,1,100)) --start
,(CHARINDEX('}', SUBSTRING(conn.StyleEx,1,100)) --right_curly_bracket
- CHARINDEX('{',SUBSTRING(conn.StyleEx,1,100)) --first left_curly_bracket
+ 1 ) --length
) "first_guid_value"
,SUBSTRING(
conn.StyleEx --expression
,CHARINDEX(';' , SUBSTRING(conn.StyleEx,1,100)) + 6 --start of guid substring
,len(conn.StyleEx) - CHARINDEX(';' , SUBSTRING(conn.StyleEx,1,100)) - 7  --length of substring
) "second_guid_value"
,case
when (SUBSTRING(conn.StyleEx , 1, 2 ) = 'LF'
and SUBSTRING(conn.StyleEx , 3, 1 ) = 'S')
then 'START_CONN_GUID'
and SUBSTRING(conn.StyleEx , 3, 1 ) = 'E')
then 'END_CONN_GUID'
else null
end "FirstConnEndDirection"
,case
,CHARINDEX(';' ,conn.StyleEx,1 ) + 1
, 2
) = 'LF'
and
,CHARINDEX(';' ,conn.StyleEx,1) + 3
, 1
) = 'E'
, 2
) = 'LF'
and
, 1
) = 'S'
else null
end "SecondConnEndDirection"
from dbo.t_connector  conn
where conn.StyleEx is not null
and conn.Start_Object_ID in (select pdo.object_id  from cte_workday_etl_package_diagram_object pdo)
and conn.End_Object_ID in (select pdo.object_id  from cte_workday_etl_package_diagram_object pdo)
, cte_start_conn_elements as
( select conn.connector_id
,sattr.Name Start_Element_Name
,sattr.Type Start_Element_Type
,sattr.Stereotype Start_Element_Stereotype
,sattr.ea_guid Start_Element_guid
,sattr.ID Start_Element_ID
,sattr.Object_ID Start_Element_Object_ID
,sattr.Notes Start_Element_Notes
from cte_conn_end_guids conn
inner join t_attribute  sattr on (sattr.ea_guid = conn.first_guid_value
and conn.FirstConnEndDirection = 'START_CONN_GUID'
UNION
select conn2.connector_id
,eattr.Name Start_Element_Name
,eattr.Type Start_Element_Type
,eattr.Stereotype Start_Element_Stereotype
,eattr.ea_guid Start_Element_guid
,eattr.ID Start_Element_ID
,eattr.Object_ID Start_Element_Object_ID
,eattr.Notes Start_Element_Notes
from cte_conn_end_guids conn2
inner join t_attribute  eattr on (eattr.ea_guid = conn2.second_guid_value
and conn2.SecondConnEndDirection = 'START_CONN_GUID'
, cte_end_conn_elements as
,eattr.Name End_Element_Name
,eattr.Type End_Element_Type
,eattr.Stereotype End_Element_Stereotype
,eattr.ea_guid End_Element_guid
,eattr.ID End_Element_ID
,eattr.Object_ID End_Element_Object_ID
,eattr.Notes End_Element_Notes
inner join t_attribute  eattr on (eattr.ea_guid = conn.first_guid_value
and conn.FirstConnEndDirection = 'END_CONN_GUID'
UNION
and conn2.SecondConnEndDirection = 'END_CONN_GUID'
, cte_workday_etl_connector_objects_elements as
(select
spdo.Diagram_ID
,spdo.Diagram_Name
,spdo.Package_ID
,spdo.Package_Name
,seconn.Connector_ID
,spdo.Object_Name Start_Object_Name
,spdo.Object_Type Start_Object_Type
,spdo.Object_Stereotype Start_Object_Stereotype
,seconn.Start_Element_Name
,seconn.Start_Element_Object_ID
,seconn.Start_Element_Type
,seconn.Start_Element_Stereotype
,seconn.Start_Element_guid
,seconn.Start_Element_ID
,seconn.Start_Element_Notes
,epdo.Object_Name End_Object_Name
,epdo.Object_Type End_Object_Type
,epdo.Object_Stereotype End_Object_Stereotype
,eeconn.End_Element_Name
,eeconn.End_Element_Object_ID
,eeconn.End_Element_Type
,eeconn.End_Element_Stereotype
,eeconn.End_Element_guid
,eeconn.End_Element_ID
,eeconn.End_Element_Notes
from cte_start_conn_elements seconn
inner join cte_end_conn_elements eeconn
on (seconn.Connector_ID = eeconn.Connector_ID)
inner join cte_workday_etl_package_diagram_object spdo
on (spdo.Object_ID = seconn.Start_Element_Object_ID)
inner join cte_workday_etl_package_diagram_object epdo
on (epdo.Object_ID = eeconn.End_Element_Object_ID)
select distinct
s_t_element_mapping.Diagram_ID
,s_t_element_mapping.Diagram_Name
,s_t_element_mapping.Package_ID
,s_t_element_mapping.Package_Name
,s_t_element_mapping.Connector_ID
,s_t_element_mapping.Start_Object_Name
,s_t_element_mapping.Start_Object_Type
,s_t_element_mapping.Start_Object_Stereotype
,s_t_element_mapping.Start_Element_Name
,s_t_element_mapping.Start_Element_Object_ID
,s_t_element_mapping.Start_Element_Type
,s_t_element_mapping.Start_Element_Stereotype
,s_t_element_mapping.Start_Element_guid
,s_t_element_mapping.Start_Element_ID
,s_t_element_mapping.Start_Element_Notes
,s_t_element_mapping.End_Object_Name
,s_t_element_mapping.End_Object_Type
,s_t_element_mapping.End_Object_Stereotype
,s_t_element_mapping.End_Element_Name
,s_t_element_mapping.End_Element_Object_ID
,s_t_element_mapping.End_Element_Type
,s_t_element_mapping.End_Element_Stereotype
,s_t_element_mapping.End_Element_guid
,s_t_element_mapping.End_Element_ID
,s_t_element_mapping.End_Element_Notes
from cte_workday_etl_connector_objects_elements    s_t_element_mapping
GO
[/color][/size][/font]
