Author Topic: UML Types in MDG --> use in project  (Read 15283 times)
vrieg
« on: October 31, 2024, 05:58:57 am »
I added UML Types e.g. taggedvalues to an MDG .
However within the project I dont see them. How can I access those tagged values from am MDG that is included as xml reference in EA16?
Sunshine
  • Its the results that count
Re: UML Types in MDG --> use in project
« Reply #1 on: October 31, 2024, 03:13:01 pm »
I've included UML Types in an MDG however, it was to ensure that tagged values were typed on the defined stereotypes. For example a couple of date Tagged Values on a stereotype like Installed Date [Date], Retired Date [Date] on an Application [Stereotype].
Not sure if just defining the UML Types alone and putting them in an MDG works actually. I can't see them in my model which uses the MDG I created either but they work for the tagged values.
You might want to try another way such as an export/import of reference data found under Settings tab>Transfer>Export Reference Data...
Happy to help
vrieg
« Reply #2 on: October 31, 2024, 11:33:34 pm »
yes this is what i did now I added them to the mdg in term of xml document and had to ensure to import the uml types again to the projects.
I need this to use sparx importer/exporter to office and to enable transferring information from/to stereotypes
