Author Topic: Can you simulate the basic activity diagram example in EA documentation?  (Read 11889 times)
mse
I noticed that the CreateObject action does not show up as documented. Although I set the classifier, the action in my case shows the label "CreateObject1" instead of "CreateObject: Class1". Is anyone else observing this behavior? I have EA version 16.1.1627 (Build: 1627) - 64 bit
« Last Edit: November 25, 2024, 10:31:03 pm by mse »
Takeshi K
    • Sparx Systems Japan
Re: Can you simulate the basic activity diagram example in EA documentation?
« Reply #1 on: November 26, 2024, 10:18:45 am »
Hello mse,
As you wrote, on my machine the CreateObject has no classifier name like 'CreateObject1: Class1' but I can get the instance and show its attribute value via an ActionPin in the next Action.
I use the build 1704 x64 (not tested on the build 1627), so it might be fixed or you might fail some setting.
t-kouno
