Author Topic: Tips: How to save several changed tabs by using a shortcut key  (Read 15646 times)
miksko
« on: November 28, 2024, 11:57:43 pm »
One feature I envy fellow developers, who use the Eclipse IDE, is the ability to save all changed tabs with one click. In Sparx you may do this by right-clicking arbitrary diagram tab and select Save all from the context menu, but there is no key combination readily available.
There is a feature in Sparx however, which lets you set up a key combination to represent a menu selection. For the case above you would do like this:
  • Select the menu option Start-> Appearance-> Preferences-> Toolbars. Sparx opens the dialogue window Customize.
  • Click the tab Keyboard and Sparx will display a form.
  • Set the Category drop-down menu to Window.
  • The list Commands will display all commands available within that category.
  • In that list, select the option Save All Modified.
  • The field Current Keys displays the shortcut keys currently bound to that command, if any.
  • Put the cursor in the field Press New Shortcut Key and press the combination of keys you want to use.
  • Press the button Assign to make it stick and then close the dialogue.
Re: Tips: How to save several changed tabs by using a shortcut key
« Reply #1 on: November 30, 2024, 03:28:19 pm »
"Noice" as we say here in Oz...
