Author Topic: Viewing connector stereotypes in traceability pane  (Read 17316 times)
andy__d
« on: December 14, 2024, 02:16:09 am »
Is there a way to display the stereotype of a connector in the Traceability window user interface? We have a number of relationships between objects that are specific to our environment, and we've used a "Connector" to create that association, and applied a stereotype to that connector to differentiate between the connection types. However, this is only visible on diagrams, I've not found a way to make that visible in the traceability window. Not all of these connectors exist in diagrams, so whilst "Find in Diagrams" can be a good solution, it doesn't work for all of our objects. If not, is there another UI element that displays connectors that I could be using instead (which also displays the connector stereotype?) Thanks!
Re: Viewing connector stereotypes in traceability pane
« Reply #1 on: December 14, 2024, 09:43:52 am »
Hi Andy,
I've recently noticed this too!  We also make extensive use of stereotypes to provide specialised semantics.  Lacking the stereotype in the Traceability pane is a hindrance,
Put in a Feature request, referencing this post and the Sparxians can gauge the support by looking at other's responses.
+1
« Reply #2 on: December 15, 2024, 08:18:01 pm »
I thought the meaningForwards and meaningBackwards is used in the Traceability window isn't it?
« Reply #3 on: December 16, 2024, 11:22:39 pm »
It is, Geert, but technically, that's not quite the same as the stereotype.  While stereotypes must be unique within an MDG, the meanings need not (as we've discovered - trying to rectify some technical debt in our MDG).
« Last Edit: December 16, 2024, 11:33:52 pm by Paolo F Cantoni »
Sunshine
  • Its the results that count
« Reply #4 on: December 17, 2024, 01:52:12 pm »
As far as I can recall the only way to see the list of relationships of an element with stereotypes is to open the element properties dialog and look at the list of links/ connectors.
Happy to help
