Author Topic: Suppress activations bar for a custom diagram  (Read 25410 times)
elr
« on: January 01, 2025, 03:19:15 am »
Hello all,
In my MDG metamodel, I'm adding up a sequence diagram to my <<diagram profile>>.
Is there a way to configure it without activations bars by default ? I don't spot any related parameter (in styleex and pdata) for the Diagram_Sequence metaclass. Weird ?!
Thx you and best wishes for 2025 !
Eric
Takeshi K
    • Sparx Systems Japan
Re: Suppress activations bar for a custom diagram
« Reply #1 on: January 06, 2025, 10:00:53 am »
Maybe adding 'SuppressFOC=1;' to the StyleEx could solve your problem.
t-kouno
elr
« Reply #2 on: January 06, 2025, 10:13:57 am »
That works. Thank you Takeshi !
I understand that User Guide 'MDG Technologies' is not the only guide to read as it never refers to 'SuppressFOC'   :o
Where this 'SuppressFOC=1' documented ?
Eric
« Last Edit: January 06, 2025, 02:44:59 pm by elr »
Takeshi K
« Reply #3 on: January 06, 2025, 04:07:49 pm »
Great to hear that the information has helped you.
I do not know the document which the setting is mentioned, but it is easy to find it by checking a difference in the t_diagram (in this case) table after changing the target setting.
t-kouno
elr
« Reply #4 on: January 08, 2025, 10:18:28 am »
Hi Takeshi,
Without doc, I have no clue how you can determine the keyword (here 'SuppressFOC') just by comparing an option-enabled release and an option-disabled's one  :-\
Does EA provides means or do we require a DB inspection ?!
Thx for your help !
Eric
Valery Creux
« Reply #5 on: January 10, 2025, 02:01:19 am »
Some of them are describe in the book "Inside Enterprise Architect - Querying EA’s Database" from Thomas Kilian
See http://leanpub.com/InsideEA
elr
« Reply #6 on: January 11, 2025, 03:29:41 am »
Thank you Valery  for pointing me this source !
