Author Topic: Model Integration for Microsoft Office  (Read 21213 times)
Modesto Vega
« on: January 10, 2025, 12:54:03 am »
I just noticed there is a new release of Model Integration for Microsoft Office dated 31 October 2024.
Has anybody used it?
Is it backwards compatible with v16.1? Or does it only run on v17?
Sunshine
  • Its the results that count
Re: Model Integration for Microsoft Office
« Reply #1 on: January 10, 2025, 12:38:56 pm »
I've used it on both V16.1 and V17 seems to work ok. The only gotcha is to make sure you use the same 32/64bit for all the components like Sparx EA, MS Office 365 and the MDG Office Integration.
Happy to help
Modesto Vega
« Reply #2 on: January 10, 2025, 09:30:33 pm »
Thank you, I will give it a try with v16.1
[SNIP]The only gotcha is to make sure you use the same 32/64bit for all the components like Sparx EA, MS Office 365 and the MDG Office Integration.[/SNIP]
It will be helpful if it is easier to differentiate, through a version or build number, if the installed software is 32 or 64bit.
« Reply #3 on: January 13, 2025, 08:16:21 am »
Match the architecture for MDG for Office to the architecture of Microsoft Office. The architecture of EA can be different.
