Author Topic: Sparx EA to crash - v17 streamed from Citrix  (Read 35622 times)
didier.pironet
« on: January 10, 2025, 02:10:47 am »
Hi guys,
Sparx EA v17.0.1703
Citrix environment
MSSQL Database
PCS enabled
So every time I select two objects and still have ctrl key pressed in while going to the align menu, Sparx hangs and crashes shortly with a popup saying the instruction at 0x.... referenced memory at 0x..... The memory could not be read issue.
This behavior can be reproduced on and on.
Is this a bug in this version/build?
Are other having the same behavior?
Thx for you help,
Re: Sparx EA to crash - v17 streamed from Citrix
« Reply #1 on: January 10, 2025, 11:06:11 am »
I'm not familiar with any similar reports and can't reproduce it in 1705.
Can it be reproduced without Citrix?
Ctrl+right click shows provides access to the toolbox. Do you have any pinned pages in the toolbox? Are you using a standard technology? If so, which toolbox is showing?
melmedarda
    • Chill Guy Clicker
« Reply #2 on: January 23, 2025, 12:38:21 pm »
I think there is a bug in the version, a Citrix compatibility issue, or conflicts with PCS or memory handling.
« Reply #3 on: January 24, 2025, 09:45:54 am »
We don't support running on Citrix, so I wouldn't be surprised if there were compatibility issues.
« Reply #4 on: January 24, 2025, 06:07:19 pm »
Hi Eve, this is the first I've heard of it. Is this documented on the website?
I have several clients running EA on Citrix for years without any issues.
« Reply #5 on: January 29, 2025, 09:10:10 am »
System Requirements are specified in a positive way. ie. We support X, rather than we don't support Y.
We don't have a Citrix environment to test in. Even if it mostly works, when an issue comes up we are unable to help.
The same would be said for Parallels and a potentially infinite number of systems that we don't claim to support or explicitly state that we don't support.
