Author Topic: Does Visibility Levels work in WebEA as well?  (Read 14280 times)
miksko
« on: January 10, 2025, 10:12:58 pm »
All elements in a model is stored in the same t_object database table. So, if you need to restrict some user's access to certain branches of your model, you will have to use the Visibility Level feature which works on row-level in the database: https://sparxsystems.com/enterprise_architect_user_guide/17.0/the_model_repository/visibility_levels.html
The mechanism is dependent on each user's database account and its security permissions. Will that user account and its restrictions be reflected in WebEA, in case you add user login to WebEA, or does WebEA use a common web server account to access the content of the database (like a number of older web tools do)?
