Author Topic: Extend a Menu  (Read 18846 times)
Viking
Extend a Menu
« on: January 29, 2025, 05:38:45 am »
Hi, I created a menu and everything works fine. The menu appears, when I hit my created Add-In button under “Specialize”. Maybe this is all I can get.
But if I remember correctly, it is / was also possible to add a menu-item to the right-click-menu / context menu as “Extensions”. The manual is a little bit "misleading" here because it does not show pictures / the result. But I found an example from Gert Bellekens at https://bellekens.com/2015/01/11/using-add-in-menu-with-ea-matic/. That shows “Extensions”.
So, my question is: is it possible to change a standard-menu and if yes, how?
As I said, my menu works. I followed the manual and checked with the example from Gert.
Re: Extend a Menu
« Reply #1 on: January 29, 2025, 09:17:44 am »
Yes.
Just a difference in the menu name on our side.
No.
Viking
Re: Extend a Menu
« Reply #2 on: January 29, 2025, 06:09:50 pm »
Many thanks, @Eve.
Viking
Re: Extend a Menu
« Reply #3 on: January 30, 2025, 06:14:31 pm »
My question was not precise enough. I did not know that the menu item “Specialize” appears in each context menu. In each of the context menus appear the custom add-in with its name (and not "extensions") as part of "Specialize". The menu of the custom add-in is on demand, it is created by each click. So, the menu could reflect for what it is needed currently for the respective
-   Diagram.
-   Element.
-   Each entry in the Project Browser.
-   Menu bar.
-   Relationship.
-   Something else?
« Last Edit: January 30, 2025, 06:17:22 pm by Viking »
Re: Extend a Menu
« Reply #4 on: January 30, 2025, 06:41:36 pm »
Yes, you can completely customize the menu entries (within Specialize|<YourAddin>) depending on the selected item and location (diagram, treeview, menu)
