Author Topic: Opening XML-file with EA 17.0.1704 64 bit gives error  (Read 15104 times)
Jacob Vos
« on: January 30, 2025, 01:51:56 am »
We get the following error when trying to open via 'Get Package...' XMI-files. At one user with 17.0.1704 64 bit everything goes fine, at another user with the same version it gives this error. At that user, with the 32 bit version there is no error. Both users use a .qea file.
What can cause this error? The error:
Enterprise Architect (Buiild: 1704 - 64 bit)
Sparx Systems Database API [0x00001072]
SQL API Open FAILED with error: near "C": syntax error
Context:
Select Package_ID from t_package where ea_guid='Error:
Code = 0x0
Source = Line : 0; Char : 0
Error Description = unable to open primary document entity 'C:\Users\<username>\Documents\svn.geostandaarden.nl\01 BROcommon\brocommon_conceptueel_MIM.xml'
Re: Opening XML-file with EA 17.0.1704 64 bit gives error
« Reply #1 on: January 30, 2025, 07:49:14 am »
Reminder that this is primarily a user forum. If you want help from the Sparx Systems technical support team you'll need to use the 'Report a Bug' link at the bottom of this page.
shimon
« Reply #2 on: February 03, 2025, 10:30:49 pm »
Maybe the UserName has non-standard letters?
I would test it after saving the XMI to C:\Temp.
Maybe the difference is in the Office version (or any other Windows Data Access components) that EA uses to import data.
I can't remember if EA uses the Windows data access for qea files. If it doesn't, then it has nothing to do with what I wrote.
Shimon
