Author Topic: MDG apply type or add type triggers  (Read 8515 times)
EXploringEA
« on: September 02, 2013, 06:18:57 pm »
Hi
I'm using an MDG and adding elements to one of my existing element on my custom diagram i.e. so that they are owned by the existing element.  It all works fine however in performing this task I don't like that EA offers me the option to ADD or APPLY the type to the Element but I assume that somewhere in the definition I should have set something to enable / disable this behaviour.
I've clearly missed what is probably a very minor detail but in searching I can't find the information to manage this option. :-?
Can anybody direct me to where this information is likely to be.
Many thanks
EXploringEA - information, utilities and addins
Re: MDG apply type or add type triggers
« Reply #1 on: September 02, 2013, 06:40:46 pm »
I'm also not sure about it, but AFAIK this is hard wired inside EA and can not be changed by any parameter. Would be nice to see a confirmation be Sparx.
EXploringEA
« Reply #2 on: September 02, 2013, 06:46:15 pm »
Thanks for the quick response - yet again something I'll have to live with.
On a similar type of topic I've also been hunting for how Sparx add their properties menus for MDG e.g. BPMN both when adding an element to a diagram and in the context menu; seem really useful but a distinct lack of information on that.  Have you seen anything?
« Reply #3 on: September 02, 2013, 07:09:52 pm »
I'm not sure what you mean with properties menus. In general MDGs control things via tagged values and extended properties are only available for hard wired elements (like e.g. Actions which can take a variety of formats).
« Last Edit: September 02, 2013, 07:10:07 pm by qwerty »
EXploringEA
« Reply #4 on: September 02, 2013, 07:44:12 pm »
When adding a BPMN element to a diagram a menu is presented.
As an example if you create a BPMN diagram and then drag a BPMN activity - up pops a menu which represents valid values for the TaskType tagged valued.  Really cool - I thought that if I provided MDG tagged values with enumerations this what I would get as can't see why the mechanism cannot be generalised.
Similarly, if you then right click on the added activity you will see a BPEL menu item - only applies to BPMN elements - and I suspect this really is hardcode.
Looks like I'll see what Sparx come up with.
Thanks for your response.
ken.norcross
« Reply #5 on: September 02, 2013, 10:59:51 pm »
When you drag from the toolbox and get a menu, look here for _subtypeProperty
http://www.sparxsystems.com/enterprise_architect_user_guide/10/extending_uml_models/supportedattributes_2.html
« Reply #6 on: September 03, 2013, 12:51:41 am »
Use the method ken.norcross suggests.
I don't see this menu. Probably because it's license restricted (I have Corporate). So your assumption is probably right that this is hard wired.
EXploringEA
« Reply #7 on: September 03, 2013, 01:00:54 am »
Ken
many thanks - clearly missed this.
Also the information you provided in the other post on subtyproperties
I'll go and have a play :)
EXploringEA
« Reply #8 on: September 03, 2013, 01:03:56 am »
@qwerty
Thanks for the feedback - interesting that the menu may be licence limited;  I need to remember and as you say probably hardwired.
I've pinged Sparx for confirmation.
Now a few hours of fun seeing if I can master the subtypeproperties
« Reply #9 on: September 03, 2013, 02:10:28 am »
Good luck. And yes: would be nice to see any confirmation from Sparx.
« Reply #10 on: September 03, 2013, 09:39:13 am »
It offers the choice because both options are valid. You can use Ctrl+Drag to apply the stereotype or Shift+Drag to add a new element.
