Author Topic: taggedValue not in Package, but in some Element?  (Read 20885 times)
avanzwol
« on: February 14, 2025, 07:38:28 pm »
I am maintaining some legacy C# code. I have Elements and Packages that where iterated through with COM objects to get the taggedValues. I noticed this is very slow.
So now I want to do it with queries and put the records in Dictionaries or Lists.
Let's say I have a Package with a Tag "A" with the value "Foo".
With a query
SELECT Object_ID, Property, Value FROM t_objectproperties I get all the Tags.
In my C# project I am iterating through the tree up to the root to get the Package with this taggedValue "A". But I noticed I cannot find it. A colleague told me that this Package has an Element which contains the Tag "A".
So now I use also the query
SELECT Object_ID AS Child_ID, Package_ID AS Parent_ID FROM t_object to iterate through the child Elements.
But when I find the Package I noticed it has three child Elements. If another child Element also has the Tag "A", things can get very messy. I don't want the Tag of some other sub-branch. So how do I know which Element I need?
Re: taggedValue not in Package, but in some Element?
« Reply #1 on: February 14, 2025, 08:22:01 pm »
For each package (record in t_package) there is a single element (record in t_object)
Both records have the same ea_guid.
Tagged values are connected to elements (t_object) and not packages.
So to select all tagged values of your package you do
select * from t_objectproperties tv
inner join t_object o on o.Object_ID = tv.Object_ID
inner join t_package p on p.ea_guid = o.ea_guid
where p.ea_guid = '{17A598AA-0796-41ef-8435-6F6852F18ECE}'
and tv.Property = 'TagA'
avanzwol
« Reply #2 on: February 17, 2025, 08:14:18 pm »
@Geert Thanks, that makes it a lot clearer to me!
avanzwol
« Reply #3 on: February 17, 2025, 10:06:00 pm »
I'm not that experienced in queries, but now I would like to append the result of the query with the rest of the t_objectproperties records without getting double results.
This is what I have so far, but this is with double records:
select tv.Object_ID, tv.Property, tv.Value, p.ea_guid from t_objectproperties tv
union select tv.Object_ID, tv.Property, tv.Value, '' from t_objectproperties tv
I tried outer join, but that keyword is not valid I think.
« Reply #4 on: February 18, 2025, 12:28:09 am »
I have no idea what you mean. What exactly are you looking for, and where are the "duplicates"?
union gets rid of any duplicates, so you must mean something else.
avanzwol
« Reply #5 on: February 18, 2025, 12:55:21 am »
Let's say I have the following t_objectproperties:
Object_ID;Property;Value;
1;AAA;Foo;
1;BBB;Bar;
2;CCC;Zoo;
And let's say taggedValue "2;CCC;Zoo;" is a tag belonging to a package A. With your query I am able to get:
Object_ID;Property;Value;ea_guid;
2;CCC;Zoo;{guidPackageA};
But I would like to have
1;AAA;Foo;;
1;BBB;Bar;;
(and with my query I get
1;AAA;Foo;;
1;BBB;Bar;;
2;CCC;Zoo;;
How do I get the result without duplicate "2;CCC;Zoo;"?
« Last Edit: February 18, 2025, 01:11:32 am by avanzwol »
« Reply #6 on: February 18, 2025, 01:53:24 am »
So you are saying, you want to see all tagged values that exist, but if they happen to be connected to a package, you want to see the package guid?
In that case you can simply make the inner join an outer join
left join t_package p on p.ea_guid = o.ea_guid
« Last Edit: February 18, 2025, 04:04:18 pm by Geert Bellekens »
avanzwol
« Reply #7 on: February 18, 2025, 02:23:29 am »
That's is what I tried. But I do get an error:
Incorrect syntax near the keyword 'join'.  :( So the keyword 'outer' is not a valid keyword?
« Reply #8 on: February 18, 2025, 04:03:59 pm »
Sorry, must me "left" instead of "outer". I don't know where my head was. :-X
avanzwol
« Reply #9 on: February 18, 2025, 09:32:48 pm »
Thanks! That's it!
