Author Topic: EA v 17 xml import links missing  (Read 33359 times)
philchudley
« on: February 18, 2025, 11:29:17 pm »
Hi All
Not sure if anyone else has experienced this bug:
1) Create a small qea repository containing two diagrams, drag one diagram onto the other as a Navigation Cell. All works as expected.
2) Export this repository to xmi v 2.1
3) Create a new qea repository and import the file created in 2) above
The navigation cell does not have it Hyperlink property and hence no longer works as expected  >:(
I have also observed that composite activities and interaction occurrences also loose their links when imported  >:(
Will report as a bug.
I am thinking of a script to fix the import, but cannot find where in the repository the Navigation Cell hyperlinks are stored. I thought it would be t_xref, but does not appear to  be the case. Does anyone know where Navigation Cell hyperlinks are stored?
Phil
Models are great!
RodneyRichardson
Re: EA v 17 xml import links missing
« Reply #1 on: February 28, 2025, 10:25:50 pm »
Does it need to be XMI? The Native XML (round-trip) format works fine. It essentially exports it as database tables.
philchudley
« Reply #2 on: March 03, 2025, 09:29:27 pm »
Thanks for your reply
Yes you are correct in that an export / import via Native works perfectly ... however when the Model Builder (wizard) attempts to import a Native XML file ... nothing is imported  >:(
This Model Builder bug is my main issue.
All the best
Phil
Models are great!
