Author Topic: EA.DocumentGenerator and Hyperlinks  (Read 7693 times)
zalbina
« on: August 06, 2013, 06:23:38 pm »
Is it possible to write into the word document hyperlinks using EA.DocumentGenerator?
Thanks.
Ian Mitchell
Re: EA.DocumentGenerator and Hyperlinks
« Reply #1 on: August 06, 2013, 07:39:18 pm »
Not sure about RTF, but with eaDocX you can create LOADS of hyperlinks within your document.
We think it makes big documents much more readable. You can make documents which have a smaller 'main' part - which you really want the reader to look at - and lots of appendices, linked from the 'main' bit with  hyperlinks, which your readers MIGHT want to read.
www.eaDocX.com
www.theartfulmodeller.com
chrisHauert
« Reply #2 on: September 05, 2013, 10:08:55 pm »
tmho you can use the hyperlink icon on the toolbar in the notes view/field of any element in order to reference to EA repository internal elements and features as well as to external sources and urls. With internal references to elements, diagrams etc. the document generator also generates document internal hyperlinks to the first occurrence of the referenced item in the generated document.
Cheers, Christoph
