Author Topic: MDG in EA 16  (Read 55215 times)
bilon
MDG in EA 16
« on: May 08, 2025, 12:03:00 am »
We are currently upgrading from mix of versions 12 and 13 to version 16. In the version 16 we face the problem with visibility of our MDG in the "More tolls" of the Toolbox. We can't see it there. But we can see it in the "Find toolbox item" window. Are there any changes in handling of MDG technologies between versions 13 a 16?
Here are some pictures.
v12 More tools menu: https://drive.google.com/file/d/1E7IsYwTt0RhyVCcegK_Nqut_DOeGHOS9
v16 More tools menu: https://drive.google.com/file/d/1ykB1GWbYyPA8u7K1p1zH5twumRtRE-Ao
v16 Find toolbox item window: https://drive.google.com/file/d/1IMBhI3zDa0wW5aFRSeGBQU_bHl7eWLol
v16 MDG technologies: https://drive.google.com/file/d/18YsfRAggtwBmtR-eYztNr2p3Cn_lZrPA
Re: MDG in EA 16
« Reply #1 on: May 08, 2025, 12:27:16 am »
Probably due to the perspective you have selected.
bilon
Re: MDG in EA 16
« Reply #2 on: May 08, 2025, 12:36:33 am »
I don't think so. I selected All.
Takeshi K
    • Sparx Systems Japan
Re: MDG in EA 16
« Reply #3 on: May 08, 2025, 08:36:13 am »
Hello bilon,
The 'All' does not mean 'everything', but all MDG Technologies that are included in the currently defined Perspective sets. If I understand correctly, if you do not add your own Perspective and add your own MDG to the Perspective, 'All' will not include your MDG.
I think Geert's comment is spot on.
t-kouno
Modesto Vega
Re: MDG in EA 16
« Reply #4 on: May 08, 2025, 06:30:36 pm »
Hi Bilon,
Under Perspectives (Design\Portals\Perspectives), do you see Model based-sets or Personal listed there? Is your MDG listed anywhere under those 2 groups?
Our MDG shows under Model based-sets.
Geert/Takeshi - Frankly, I do not fully understand the concept of perspectives in Sparx EA. I know it is there, I know people talk about it but I still not fully understand the role and Sparx Systems categorisation.
Takeshi K
Re: MDG in EA 16
« Reply #5 on: May 08, 2025, 06:38:21 pm »
Neither do I.  ;)
t-kouno
Modesto Vega
Re: MDG in EA 16
« Reply #6 on: May 08, 2025, 07:58:21 pm »
Thank you for making me not feel so lonely  ;)
Re: MDG in EA 16
« Reply #7 on: May 08, 2025, 09:48:29 pm »
The way I use it is to create a single perspective with all the MDG we use in an organisation, and then create a perspective set that includes only that one perspective.
That perspective set is then set as the default one for all users.
This ensures us that noone will start modelling using stereotypes from some weird niche MDG that nobody else ever heard of.
bilon
Re: MDG in EA 16
« Reply #8 on: May 12, 2025, 06:35:15 pm »
Hi all,
Thank you for your responses. Like Modesto and Takeshi, I must say that I do not understand the concept of perspectives. I have no idea what to do, to be able to work with my MDG. To open it every time through the "Find toolbox item! window is very clumsy.
@Modesto Vega, unfortunately I can't see my MDG in the groups mentioned by you, they are both empty.
Re: MDG in EA 16
« Reply #9 on: May 12, 2025, 06:55:47 pm »
Hi all,
Are you sure you have actually have an MDG technology?
Back in the day it was more common to simply have a UML profile and import that.
That doesn't really play nice with the perspectieves and stuff, since they sort-of assume each UML profile is packaged into an MDG technology.
If you don't have an MDG technology, it's pretty easy to create one, but you'll need to setup diagram types and toolboxes to use it easily.
bilon
Re: MDG in EA 16
« Reply #10 on: May 12, 2025, 07:01:34 pm »
You can see, in the last picture I posted, activated technology called BIF. So what else I should do?
Re: MDG in EA 16
« Reply #11 on: May 12, 2025, 07:44:24 pm »
Does your MDG include a diagram extension and a toolbox?
If you expand your MDG in the resources tab, you should see something like "UML Profiles", "Diagram Types" and "Toolboxes"
bilon
Re: MDG in EA 16
« Reply #12 on: May 12, 2025, 09:39:18 pm »
I'm not sure what you mean with resources tab. I found a tab titled "Resource Allocation", but it is empty.
Re: MDG in EA 16
« Reply #13 on: May 12, 2025, 11:10:46 pm »
One of the tabs on your project browser is called "Resources" (the others are Project, Context, Diagram)
It's where you find docgen templates, MDG's etc...
bilon
Re: MDG in EA 16
« Reply #14 on: May 13, 2025, 12:06:27 am »
Yes, I've finally found it under System Technologies. My MDG contains only UML Profiles and Scripts.
