Author Topic: Setting the type of Activity Parameter  (Read 23554 times)
Jos Fries
« on: May 12, 2025, 09:22:40 pm »
On addition of an Activity Parameter to an Activity, the default type of the parameter is an Integer. According to https://sparxsystems.com/enterprise_architect_user_guide/17.0/modeling_languages/activityparameternodes.html the type of the parameter can be changed via the 'Parameter' tab of the 'Properties' dialog. That tab seems to be missing from the dialog however, or am I overlooking something? How can the type of an Activity Parameter be changed? I'm using EA 17.1 build 1710.
Re: Setting the type of Activity Parameter
« Reply #1 on: May 12, 2025, 11:17:41 pm »
You have to look in the (docked) properties window, not the (popup) dialog
Jos Fries
« Reply #2 on: May 13, 2025, 04:29:12 pm »
Ah, found it! Thanks!
Jos
