Author Topic: v16 Database Builder does not read VIEW COLUMNS from Oracle DB  (Read 26949 times)
rmkk
Hi, I'm using DBB to read structures from Oracle. Tables are loaded well including table columns. However VIEWS are loaded without view columns. Is there a workaround for that ? I read somewhere that the is an option to "Import from DDL" but I can not find this option. Many thanks for help.
Richard Freggi
Re: v16 Database Builder does not read VIEW COLUMNS from Oracle DB
« Reply #1 on: May 24, 2025, 12:07:41 am »
I think this is normal.  I extract the column names by querying Oracle metadata and import them into the model with the Belleken importer.
Sunshine
  • Its the results that count
« Reply #2 on: May 24, 2025, 12:05:10 pm »
Have you tried a different option to connect to Oracle DB. I have a distant memory of reverse engineering an Oracle DB which didn't import everything I was expecting and the solution was to use a different way of connecting to the DB. IIRC it was either a version of the driver or ODBC vs OLEDB.
Happy to help
