Author Topic: Scripting element interaction points "visible" property  (Read 25446 times)
chrislro
« on: May 27, 2025, 06:43:08 pm »
I have scripted creation of provided and required interfaces as child elements of a component. By default in a diagram, new "interaction points" are set to not visible. I can tick the boxes (Features > Interaction Points) manually in EA, but how can I script (JScript) setting the newly created provided/required interfaces to "visible"?
Re: Scripting element interaction points "visible" property
« Reply #1 on: May 27, 2025, 07:16:48 pm »
You can update the diagram property that is changed when ticking the box.
I'm guessing the property will be written in the StyleEx, but it might also be Pdata
chrislro
« Reply #2 on: May 27, 2025, 07:27:54 pm »
Thank you for pointing me to it. I never worked with those before, so I need to jump into this rabbit hole.
