Author Topic: Shared QEAx on a network drive  (Read 31473 times)
Guillaume
    • www.umlchannel.com
« on: June 04, 2025, 10:13:06 pm »
A client with a small team of users cannot set up a shared DB as this stage so we identified the option to put a QEA file on a network drive.
EA 16 or 17 64 bits will be used and I'm interested in some feedback about this mode:
- Is it still valid to say that it works ok for up to 5 concurrent users ?
- Sparx EA user guide mentions System crashes on EAPX files ; do QEA SQLite files operate ok in case of a machine or network issue ?
- Does the EA security with permissions and locks operate fine like with a proper DB ?
Anything else I should be aware ?
Guillaume
Re: Shared QEAx on a network drive
« Reply #1 on: June 04, 2025, 10:21:10 pm »
- User locking/security should work exactly the same.
- Make sure you have a proper backup of the file.
- Use a "real" shared drive, and not some OneDrive or Sharepoint stuff
- Check SQLite documentation about limitation and risks
Guillaume
« Reply #2 on: June 04, 2025, 11:00:21 pm »
Hi Geert,
Thank you for your feedback.
SQLite documentation goes against sharing a file over the network as it warns against performance and reliability/data corruption risks:  https://www.sqlite.org/useovernet.html
I wonder if there's any recommendation from Sparx on sharing a QEA file over a network drive.
If anyone has tried this setup, please let me know.
I will run some tests locally in the meantime.
Guillaume
