Author Topic: Improve/implement C language support  (Read 90497 times)
guido.albertin.infineon
« on: June 09, 2025, 09:37:16 pm »
Implement the C language support for activity diagrams, state machines and sequence diagrams?
The current distributed environment just creates the empty bodies, given that the language support is mostly empty.
Is there a chance it may be derived from the C++ template? Am I losing some important bit here?
Takeshi K
    • Sparx Systems Japan
Re: Improve/implement C language support
« Reply #1 on: June 10, 2025, 08:31:16 am »
Even if you use the Unified or Ultimate edition, you need to enable the 'Object Oriented Support' model option to generate C source codes from the behavioural diagrams such as the Activity diagrams, the Statemachine diagrams.
t-kouno
