Author Topic: Bug in export to XMI: SQL API Open FAILED with error -- Images  (Read 32523 times)
aloeffen
Case description:
Some EA project export with SQL errors due to flawed image ID recognition routine.
How to test:
In EA 17 create a class diagram and a class with some tagged value. Set the value to id=00001&type=term
Export to XMI 1.1 or 1.2
Result:
The SQL query that collects images to export (cf. image manager) causes API error: SQL API Open FAILED with error: no such column: term
If images are introduced in notes fields, none of these images are exported.
Possible reason:
The routine that finds references to images triggers on id= anywhere in de value and all text that follows it.
- This method of identifying images is flawed.
- The & is the reason the SQL query fails.
Impact:
Very big impact for projects that rely on XMI exports that use, for example, URL values for tagged values as in http://www.sample.com?id=00001&type=term.
The export is halted, waiting for user okay.
Tested on:
EA 17.0.1704 64 bit
Re: Bug in export to XMI: SQL API Open FAILED with error -- Images
« Reply #1 on: June 28, 2025, 01:58:03 am »
Hmm, SQL Injection anyone?
