Author Topic: bulk positioning multiple embedded elements (interfaces) of a component?  (Read 21170 times)
chrislro
Hi all,
I got a diagram showing a component including its embedded provided and required interfaces. It has a lot of them, and I want to show them readable. Also, I have to add "usage" connections to other components in the same diagram. So I need to move and align a lot of elements.
Is there a way in EA 17.1 to move a block of mouse-selected interface on the components surface? I can mouse-select the interfaces as a group and at first glance it looks like I can mouse-drag them to e.g. to the other side of the same component, but nothing happens when releasing the mouse press. Distribute equally works, but not moving around. Also I would love to keyboard-move one or more embedded interfaces on a components surface. Nothing works.
Is this not supported or do I use the wrong keys/means?
PDC
  • Systems Engineer
As far as I know this is the expected behaviour in all versions of EA to date. I think everyone would agree it would be desirable to be able to move multiple exposed interfaces at once, but for whatever reason this is how the tool behaves.
Phil
chrislro
Thank you. Still sad. I'll post a feature request ...
