Author Topic: Not being able to type a FlowProperty with a Signal  (Read 62265 times)
EAButNotForGames
« on: August 19, 2025, 07:34:49 pm »
Does anyone have the same Poblem?
I am using Build 1710
PDC
  • Systems Engineer
Re: Not being able to type a FlowProperty with a Signal
« Reply #1 on: August 20, 2025, 05:26:32 pm »
This is of no help to you but I can confirm it does work in 1625 and there's nothing in the release history to suggest that this functionality has been altered in any way since then.
Sorry I don't have 1710 to hand to help you out further.
Out of interest, how are you trying to apply the signal type to the flowproperty?
Phil
EAButNotForGames
« Reply #2 on: August 20, 2025, 06:09:18 pm »
In the properties window of the FlowProperty, under Type.
This worked in older EA Versions. I used it through Version 16. And I am pretty sure it worked in the release version of 17.
I was trying to model the signal flow in an IBD. And while creating the InterfaceBlocks I noticed this bug.
Based on the SysML specification: "A FlowProperty shall be typed by a ValueType, Block, or Signal."
Value Type and Block still works though.
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: August 21, 2025, 08:55:34 am »
Just FYI,
With my free SysML add-in, we can create a FlowProperty with a Signal by dragging a Signal in the Browser onto an InterfaceBlock on a diagram. We do not need to have two (or more) steps to define an InterfaceBlock for a Signal.
https://www.sparxsystems.jp/en/SysML/
t-kouno
PDC
  • Systems Engineer
« Reply #4 on: August 21, 2025, 05:30:55 pm »
Yeah you're doing everything that should work then I think, sounds like a genuine bug!
Phil
