Author Topic: How do you keep UML diagrams in sync with the actual code?  (Read 94655 times)
dianereesee
    • Geometry Dash Lite
« on: September 15, 2025, 12:16:02 pm »
Hi all,
I make nice UML diagrams in EA to explain the design, but after a few months of coding… the diagrams no longer match reality.
-> The class structure changes in code, but the diagrams don’t get updated.
-> Sometimes developers ignore the diagrams completely because they’re “out of date.”
-> Reverse engineering helps, but it can also create too much detail.
-> Forward engineering is nice, but doesn’t capture everything.
Re: How do you keep UML diagrams in sync with the actual code?
« Reply #1 on: September 15, 2025, 04:11:12 pm »
There's no easy solution to that problem, but here are some tips that might help
- Make "Model and documentation up-to-date" part of your Definition of Done. An issue is not done if the model isn't updated (and should not be deployed to the next environment if not Done)
- Make sure the model and code differ enough in levels of abstraction. In general try to keep the model at a higher level of abstraction so that most code changes don't impact the model.
