Author Topic: The Diagram has been modified by another user  (Read 7227 times)
Helmut Ortmann
« on: September 12, 2013, 04:21:47 pm »
I made an Addin with:
repository.ReloadDiagram(DiagramID);
diagram.SelectedConnector = con;
diagram.Update();
I run the addin, it does what I want it to do. After a few seconds I get the message:
The Diagram has been modified by another user.
It will remain locked against modification until it is reloaded.
The the diagram is locked. It's a local *.eap file and I have only one EA instance running. EA 10.09.
Has someone an idea?
Helmut
Re: The Diagram has been modified by another user
« Reply #1 on: September 12, 2013, 04:43:04 pm »
Try adding Repository.ReloadDiagram(long DiagramID) at the end.
« Reply #2 on: September 12, 2013, 04:44:28 pm »
Or even better, forget the diagram.update(). It doesn't seem like you are changing anything to the diagram are you?
Helmut Ortmann
« Reply #3 on: September 12, 2013, 10:13:50 pm »
Hello Geert,
before Reload I make changes to line style in the diagram.
After reload I want to select the beforehand selected elements/connector. The selections get lost with reload.
Helmut
« Reply #4 on: September 12, 2013, 10:28:54 pm »
Isn't this working? You don't need an update() after setting the selectedconnector.
Helmut Ortmann
« Reply #5 on: September 12, 2013, 11:39:06 pm »
Hello Geert,
that was it. The update() makes the mess.
Thanks a lot for your effort.
Helmut
