Author Topic: Moving up/down class attributes does not work?  (Read 77386 times)
ea0425
« on: January 21, 2026, 12:00:53 am »
EA version 17.1.1713
I want to reorder UML class element attributes. There should be Move Up and Move Down options when the attribute has been selected but there is none and Ctrl+ Up/Down Arrow does nothing. "Sort Features Alphabetically" has been deselected (and the attributes are not in alphabetical order but in the order I created them).
In  the earlier EA versions I have used it was very easy to move the attributes up and down but how do you do it now? Or is this a bug?
Re: Moving up/down class attributes does not work?
« Reply #1 on: January 21, 2026, 12:23:18 am »
Are you using the features window?
That is where I do it using ctrl-up or ctrl-down
ea0425
« Reply #2 on: January 28, 2026, 08:14:46 pm »
Thank you - I finally found the Feature window, for some reason it was docked below the diagram and could not really be seen so I never noticed the window opening and was wondering why there was none in this version...
