Author Topic: Repository.GetCurrentDiagram() returning wrong diagram  (Read 47646 times)
Barrie Treloar
« on: March 31, 2026, 05:29:38 pm »
In Sparx 15.2
I have two diagrams open, Diagram A and Diagram B.
I run my VBScript from the Specialize > Script Library > Scripts > "my script" > Right click > Run Script
My VBScript calls
    dim currentDiagram as EA.Diagram
    set currentDiagram = Repository.GetCurrentDiagram()
When I printout
   "currentDiagram = " & currentDiagram.Name
it shows the wrong diagram name "Diagram B".
In
Browser > Project, Diagram A is selected
Browser > Context, Diagram A is selected
Browser > Diagram, Diagram A is selected
Main Window > Diagram A is selected
In the Main Window it is listed as "Diagram A", "Diagram B".
If I swap the order of the diagrams to be "Diagram B", "Diagram A" it prints out the correct name.
If I swap the order of the diagrams to be "Diagram A", "Diagram B" it prints out the incorrect name.
It seems to always select the rightmost diagram.
Am I doing something wrong?
Re: Repository.GetCurrentDiagram() returning wrong diagram
« Reply #1 on: March 31, 2026, 08:26:03 pm »
Current diagram looks at which diagram is open in the main window.
« Reply #2 on: April 02, 2026, 08:01:51 am »
I believe Geert has cut to the core of the issue.
The Browser is not relevant for this function at all.
It gets more complicated than that though:
  • It is possible to drag a tab from the main window out and dock it elsewhere. In that case it becomes the last of the visible main window views that you interacted with.
  • There may not be an active diagram at all. In particular if you're running from a script editor or console, that will be the active window so the current diagram will be null.
sjf
« Reply #3 on: April 15, 2026, 08:31:51 pm »
You could use:
Repository.GetTreeSelectedObject() and
RepositoryGetTreeSelectedItemType() to check if you have a diagram selected in the browser and then get the name of the browser selected object.
Barrie Treloar
« Reply #4 on: July 06, 2026, 04:14:05 pm »
Thanks for your replies.
I was perhaps too zealous in listing out all the selection places I tried and have complicated my post by erroneously adding in the Browser selection as well, since I was flailing about trying to work out why its not working.
If I clip out from the original message the minimal reproduction steps:
Then when I run my script it prints out "Diagram B", even though "Diagram A" is the currently open and selected tab in the Main Window.
While trying to create a minimal reproduction for the code I've found the problem.
After Repository.SaveAllDiagrams, then the call to Repository.GetCurrentDiagram() will always return the right most diagram and not the current diagram
==================Code==========================
option explicit
!INC Local Scripts.EAConstants-VBScript
'If Repository.SaveAllDiagrams then the call to Repository.GetCurrentDiagram() will always return the right most diagram and not the current diagram'    Repository.SaveAllDiagrams
dim name
name = "No diagram selected"
if not currentDiagram is nothing then
    name = currentDiagram.Name
end if
Session.Output  "Current diagram = " & name
