Author Topic: Pro Cloud Server 6.5 - Build 169  (Read 18007 times)
sparks
« on: July 24, 2026, 07:11:03 am »
Sparx Systems announces official release of the Pro Cloud Server Version 6.5, build 169 (PCS 6.5)
For more information on the release please see:
    https://sparxsystems.com/products/procloudserver/6.5/
For a full list of features and fixes included please see:
    https://sparxsystems.com/products/procloudserver/6.5/history.html
Both registered Enterprise Architect and Registered Pro Cloud Server Users can find download links to the PCS installers on the following page:
    https://sparxsystems.com/products/procloudserver/downloads.html
Important Notes on Pro Cloud Server v6.5
To improve Pro Cloud Server security, v6.5 includes different behavior to previous releases that could be unexpected to some users, these changes include:
 - When upgrading to Pro Cloud Server v6.5 all existing HTTP ports will not start. The only way to re-enable them is to resave their definitions (and restart the PCS), in doing so you are accepting that HTTP ports are not secure and should only be used within a private network
 - New installations of Pro Cloud Server v6.5 will not include a HTTP port. Therefore either a HTTP must be manually created or a server.pem (SSL key & certificate) created to enable the provided HTTPS port before Pro Cloud Server will accept any kind of communication from clients
 - With previous versions of Pro Cloud Server it was possible to perform a basic connectivity test using the just the server name and port of the host machine (ie http://{servername}:1804), however this now produces an error and instead the dedicated path (/connectivitytest/) should be appended to the URL, ie. https://{servername}:1805/connectivitytest/
 - Model authentication is now the only available authentication method on a Port, if your previous configurations were using None or Global, there will be behaviorial differences when EA clients attempt to connect to your repositories
 - Earlier versions of the Configuration Client are not compatible with v6.5 of the Pro Cloud Server service, therefore only use the Configuration Client that ships with the v6.5 installer
 - The IIS Integration optional component is no longer included in the installer, this function was depprecated in v3 and should no longer be used
The licensing procedures introduced in PCS 5 are still relevant to PCS 6.5 and are documented on the Pro Cloud Server download page (https://sparxsystems.com/products/procloudserver/downloads.html) under the heading "Installing and Registering Pro Cloud Server v5"
If you need any assistance in retrieving your Enterprise Architect/Pro Cloud Server credentials please contact Sparx Systems Sales Team: [email protected]
To report any issues please use:
    http://www.sparxsystems.com/registered/forms/reg_bug_report.html
