Author Topic: Database Query Restrictions in Enterprise Architect 17.2  (Read 9719 times)
emiliano.davila
« on: August 04, 2026, 12:58:44 am »
Hello everyone,
We are currently testing the upgrade to Enterprise Architect 17.2 and have noticed some changes regarding database queries.
First, we observed that it is no longer possible to query the repository security tables, such as `t_secuser`, `t_secgroup`, and `t_secusergroup`, among others.
Additionally, the `Repository.SQLQuery()` method apparently only allows `SELECT` queries, meaning that it can no longer be used to execute `INSERT` or `UPDATE` statements.
We have also encountered issues when running recursive queries using expressions such as `WITH RECURSIVE`, even when they are read-only queries.
We reviewed the published change history for EA 17.2 but could not find any information related to these restrictions.
Has anyone experienced similar behavior?
Is this an expected and permanent change in the tool, or is there any configuration that would allow these operations to be enabled again?
Thank you in advance.
Best regards,
GeordieKiwi
Re: Database Query Restrictions in Enterprise Architect 17.2
« Reply #1 on: August 05, 2026, 04:04:52 pm »
These are likely to be in response to security issues that were brought to light a few months back
« Last Edit: August 06, 2026, 06:44:18 pm by GeordieKiwi »
« Reply #2 on: August 10, 2026, 04:51:57 pm »
This has always been the case. For insert or update statements, you needed Repository.Execute(), which apparently has been disabled as well.
Helmut Ortmann
« Reply #3 on: September 12, 2026, 06:13:58 am »
I also stumbled on the issue with Update/Insert via sql and EA 17.2 (disabled).
Is there a way to set e.g. PDATA3 for a Part which points to the original part (if the part is a reference)? In the past I used sql because there is no API (readonly property).
Ok, I can access with native SQL. For sqlite this shouldn't be a big deal.
Other databases aren't always that simple.
Have someone an idea or experiences?
Helmut
« Reply #4 on: September 13, 2026, 08:09:20 am »
Helmut
I've sent an email to Sparx support, with my list of all the things I use the now retricted methods for, asking for alternatives.
I have yet to get an answer.
I'm afraid I'll have to switch to native database queries at some point.
Upside of that is that this is much much faster than Repository.SQLQuery, and you don't need to worry about the translation into xml.
sjf1966
« Reply #5 on: November 05, 2026, 08:59:10 pm »
It would also be useful if the othe MS SQL query expressions were allowed at the beginning of the text for instance common table expressions begin with "With" for example:
From https://learn.microsoft.com/en-us/sql/t-sql/queries/with-common-table-expression-transact-sql?view=sql-server-ver17
-- Define the CTE expression name and column list.
WITH Sales_CTE (SalesPersonID, SalesOrderID, SalesYear)
AS
-- Define the CTE query.
    SELECT SalesPersonID, SalesOrderID, YEAR(OrderDate) AS SalesYear
    FROM Sales.SalesOrderHeader
    WHERE SalesPersonID IS NOT NULL
-- Define the outer query referencing the CTE name.
       COUNT(SalesOrderID) AS TotalSales,
       SalesYear
FROM Sales_CTE
GROUP BY SalesYear, SalesPersonID
ORDER BY SalesPersonID, SalesYear;
This simplifies queries and would be really useful in Prolaborate too
