Author Topic: Repository.Execute no longer works in JScript  (Read 3306 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: August 06, 2026, 11:47:33 pm »
While testing the latest version of EA (17.2 build 1721), I noticed that JScripts that were working perfectly in previous versions are now failing on lines containing Repository.Execute("insert SQL here"). I am now getting an "Internal Error" when the script reaches that line.
Does anyone know if this command has been deprecated? Has it been replaced by something else?
Re: Repository.Execute no longer works in JScript
« Reply #1 on: August 10, 2026, 04:55:19 pm »
I'm guessing this is one of the "security" fixes, but I'm pretty worried about that myself.
There are quite some things that are not possible in the API without resorting to the Repository.Execute backdoor method.
If this method is indeed no longer available, that would break quite a few of my add-ins and scripts.
philchudley
« Reply #2 on: August 10, 2026, 06:29:41 pm »
I agree Geert, there's a lot of scripts I have developed for clients and myself which are going to break if they upgrade to EA v 17.2
Not good  >:(
Phil
Models are great!
« Reply #3 on: August 10, 2026, 09:58:29 pm »
I've sent an email to support about this one, and the restrictions on Repository.SQLQuery (where you can't select from certain tables anymore, e.g. t_seclocks)
Hoping for an alternative
If they can't provide an alternative solution, I'm guessing I'll have to resort to a direct database connection to execute these type of queries/updates.
The upside of that would be that it would be a lot faster then going through Repository.SQLQuery
Obvious downside if that you have to manage your own database connection.
Pierre Beyssac
« Reply #4 on: October 28, 2026, 09:29:45 pm »
Hello
I just upgraded to 17.2 on EA and I hadn't seen this post before! I had to quickly roll back, a lot of our scripts/add-ins don't work anymore because they use Repository.Execute, which is really annoying for what's next. Has there been any progress on an alternative?
-Pierre
« Reply #5 on: October 28, 2026, 11:33:30 pm »
No good news yet. There is another topic https://sparxsystems.com/forums/smf/index.php/topic,49305.0.html where Eve from Sparx commented on this topic.
I haven't heard back from support about the alternatives for my use cases.
Pierre Beyssac
« Reply #6 on: October 29, 2026, 02:54:38 am »
 :( Indeed! I just read Sparx's arguments.
Thank you Geert
