Author Topic: Import DDL Script (EA build 1721) - SQL Server (Azure SQL)  (Read 2783 times)
robert.daniels-dwyer@hs2.
« on: August 22, 2026, 01:53:08 am »
We are trying to import DDL into a SQL Server repository (running on Azure SQL on our own tenant).  We are getting an uncontrolled error with t_xref.  Sparx then creates the names of the first two tables in the .sql file, but no columns, and crashes out.
We do not get this error when loading onto a local file-based repository.
Has anyone come across this?  Does anyone have any ideas?
Enterprise Architect (Build: 1721 - 64 bit)
Microsoft Cursor Engine [0x80040e21]
Field 'XrefID' - The value violated the data source schema constraint for the field.
Context:
select *
from t_xref
where Client in
        select ea_guid
        from t_object
        where GenFile like 'C:\[Redacted]\Documents\Sparx Upload Test 30-07-26b\%'
union
select *
from t_xref
where Client in
    select ea_guid
    from t_connector
    where
        Start_Object_ID in
            select Object_ID
            from t_object
    or
       End_Object_ID in
            select Object_ID
            from t_object
Re: Import DDL Script (EA build 1721) - SQL Server (Azure SQL)
« Reply #1 on: August 24, 2026, 06:19:16 pm »
I'm guessing there is erronous data already in the t_xref. Have you tried it on a clean emtpy sql server repository?
« Reply #2 on: August 27, 2026, 12:32:47 am »
Yes.  Same error.
