Author Topic: Any trick to set preferences after my employer wipes registry settings?  (Read 963 times)
Richard Freggi
EA 17.1 Professional on Windows 11 on work computer; a few times a day the preferences for line color, not using element shadows etc. are reset to EA default (gray lines, shadows on etc.) so several times a day I need to spend 40 seconds on Preferences menu to manually set the preferences back to what I want.  Is there a way to speed up this process, such as a script?  Because it gets annoying after the 450th time.  p.s. Suggestion for future releases, DON'T store user preferences in the Windows registry please!!!
« Last Edit: August 23, 2026, 11:17:30 am by Richard Freggi »
Re: Any trick to set preferences after my employer wipes registry settings?
« Reply #1 on: August 24, 2026, 03:54:53 pm »
I use an EA-Matic script for some of the mandatory settings we want all users to have:
'[path=\Projects\EA-Matic Scripts]
'[group=EA-Matic]
option explicit
!INC Local Scripts.EAConstants-VBScript
' Script Name: Fix Mandatory User Settings
' Author: Geert Bellekens
' Purpose: Check the mandatory user settings in the registry and set them correctly if needed
' Date: 2021-05-28
'EA-Matic
const REG_SZ = "REG_SZ"
const REG_DWORD = "REG_DWORD"
const REG_BINARY = "REG_BINARY"
function fixSettings
dim regPath
Dim regkey
dim regValue
dim existingValue
'place in the registry that contains all of the user settings
regPath = "HKEY_CURRENT_USER\Software\Sparx Systems\EA400\EA\OPTIONS\"
'get the EA version
'set the default diagram layout
Repository.Execute  "update s set s.[Value] = 'l=20;c=20;d=1;cr=1;la=2;i=1;it=4;a=0;' from usys_system s where s.[Property] = 'Diagram_Layout'"
'fix registry settings
dim settingsValid
settingsValid = true
settingsValid = settingsValid AND validateRegValue(regPath, "SORT_FEATURES","1", REG_DWORD) 'commented out because of conflicts with TMF model. Has to be uncommented for Baloise
settingsValid = settingsValid AND validateRegValue(regPath, "TREE_SORT","0", REG_DWORD)
settingsValid = settingsValid AND validateRegValue(regPath, "XMI_ReportXrefDeletion","0", REG_DWORD)
settingsValid = settingsValid AND validateRegValue(regPath, "JET4","1", REG_DWORD)
validateRegValue regPath, "XSDFileName","", REG_SZ
if not settingsValid then
msgbox "Mandatory user settings have been corrected." & vbNewLine & "Please restart EA",vbOKOnly+vbExclamation,"Corrected mandatory user settings!"
Repository.Exit
end if
end function
function validateRegValue(regPath, regKey, regValue, regType)
Dim shell
' Create the Shell object
Set shell = CreateObject("WScript.Shell")
dim existingValue
on error resume next
'read registry value
existingValue = shell.RegRead(regPath & regkey)
'if the key doesn't exist then RegRead throws an error
If Err.Number <> 0 Then
existingValue = ""
Err.Clear
end if
on error goto 0
'check the value in the registry with the desired value
if Cstr(existingValue) <> regValue then
'write the correct value to the registry
shell.RegWrite regPath & regkey, regValue, regType
'return false
validateRegValue = false
else
'value was already OK, return true
validateRegValue = true
end if
end function
function EA_FileOpen()
fixSettings
end function
Richard Freggi
« Reply #2 on: August 25, 2026, 09:12:24 pm »
Thank you Geert!
