Author Topic: Generate reports from the Compare Utility?  (Read 188 times)
miksko
« on: August 25, 2026, 06:19:24 pm »
Sparx' Compare Utility lets you track the changes between the current version and a baseline. (I imagine it's possible to also let it track the changes between the current version and the latest version checked in, in case you use Sparx' built-in version control, but I haven't been able to check that.) Is it possible to use the Report Builder to generate a document from the changes (also those made in diagrams)?
I'm asking since the Compare Utility is pretty tricky to use and we don't want to force every consumer to install the client. We also want the consumers to easily be able to review the incremental changes made between minor versions, in case they are behind.
Re: Generate reports from the Compare Utility?
« Reply #1 on: August 25, 2026, 11:53:50 pm »
I don't think so. I agree that would be a useful feature.
