Author Topic: Move elements to another package by going through the diagram?  (Read 185 times)
miksko
« on: September 03, 2026, 11:19:11 pm »
Let's say I've created an activity diagram in a use case and then realize that an alternate flow should be moved to another use case. I can of course cut and paste the affected elements in the activity diagram, but the the elements will remain under the first use case; it's only the links that I cut and paste. Is there some way to perform a "deep move" in the same way you may do a "deep copy"?
