Author Topic: changing text font size and adding toolbox Legend in EA Diagrams?  (Read 145 times)
khalid.ibrahim
« on: September 24, 2026, 02:36:13 am »
I'd like to increase the font size of the text I put in an EA diagram and also add a legend that displays the artifacts I'm using (like composition links with the diamond head) in the print out of my diagrams. Is there a way I can do this?
thanks for your help.
Sparx Systems Malaysia
    • Sparx Systems Malaysia
Re: changing text font size and adding toolbox Legend in EA Diagrams?
« Reply #1 on: September 25, 2026, 09:04:57 pm »
For the default diagram font, use Start → Appearance → Preferences → Preferences → Diagram → Appearance → Default Fonts. Note that a diagram-level font can override your user default.
You can add EA’s standard legend from Toolbox → Common → Diagram Legend. However, that legend is primarily intended for appearance conventions such as colors and line widths. It does not provide entries for UML connector-end symbols such as the filled Composition diamond.
For a printed notation key, the practical workaround is to create a small legend graphic showing the required symbols and insert it into the diagram, or construct a small manual key using sample connectors and Text/Note elements.
If your team is looking to improve how your organisation uses Enterprise Architect, you can get in touch with us to learn more.
« Last Edit: September 25, 2026, 09:39:29 pm by Sparx Systems Malaysia »
khalid.ibrahim
« Reply #2 on: September 26, 2026, 03:27:34 am »
Thank you!
