Author Topic: C4 Modeling  (Read 105 times)
Typia
C4 Modeling
« on: October 08, 2026, 09:20:40 pm »
is there any official MDG for C4 ?
I can't find it on registered downloads ?
Many thanks,
Best regards
philchudley
Re: C4 Modeling
« Reply #1 on: October 08, 2026, 09:34:11 pm »
Models are great!
Typia
Re: C4 Modeling
« Reply #2 on: October 08, 2026, 11:37:55 pm »
Thanks a lot, I got it.
is there any way to package it so it can be deployed automatically ? we're in a multi user environment.
philchudley
Re: C4 Modeling
« Reply #3 on: October 08, 2026, 11:46:28 pm »
One method that I know of is:
1. Place the MDG file on a network drive that everyone can access
2. Then everyone's EA will require the following setting performed once only:
    a) Select Manage Technology from the Settings Toolbar
    b) In the pop-up dialog select Advanced... This displays a dialog where you can specify the path to the file set in 1. above
When EA loads the C4 MDG will be loaded along with all other MDGs
Each user will have to add the C4 MDG to their current active perspective.
There maybe other methods, but this is the one I have used in the past.
Phil
Models are great!
Re: C4 Modeling
« Reply #4 on: October 09, 2026, 01:07:21 am »
If you have a central database, the easiest approach is to import the MDG in the repository.
No individual configuration needed.
philchudley
Re: C4 Modeling
« Reply #5 on: October 09, 2026, 01:56:18 am »
Absolutely of course!
I think I miss-understood his post regarding deployment.  :-\
Phil
Models are great!
